points
bigblock
06-01-2007 16:52:18
I have a question ,guys,that has nothing to do with a tractor.I'm working on a 54 chevrolet bel-air ,L6 ,points,12v conversion(I think).Any way,I installed new points and condenser,gapped em to .022 fired it up and went riding.The next day I called him to come pick it up.When he got here he paid me,got in to leave and no start.There was no fire at the coil.Found a burnt wire and fixed it.Now there's smoke rolling out of the distributor.Points are melted.There's no resistor in this system.Aside from replacing the P& C again and installing a resistor What happened?It had done fine in every parade for years.What did I do wrong?
Ravgardner
06-02-2007 05:00:33
 Re: points in reply to bigblock, 06-01-2007 16:52:18
54 Chevy! Wow. My first car was 4 door 54 Chevy. I ran it 7 years through highschool, college, one year living in New York City until I replaced it with a New Saab 99 hatch back. Sorry, I regress. I agree with the previous note about starting on 6 volts. I stated college in the NY snow belt and could always get the old girl to start. I was always glad to jump start the old VW's with 6 volts that couldn't take the cold.
bigblock
06-02-2007 10:49:02
 Re: points in reply to Ravgardner, 06-02-2007 05:00:33
This one is a 4 door,black with a white top.
machinery-man
06-01-2007 19:30:32
Was there not also a wire from the starter to provide 12 only when starting. I can recall the resistor wire and on some the resistor block, generally mounted near the coil.
John T
06-01-2007 18:57:46
I wonder if the coil is still an original 6 volt coil and if so and its now a 12 volt system and theres no voltage dropping ballast of some sort ahead of the coil (maybe a resistive wire burned up as FIT mentioned), she can still work but the coil will run way too hot and the points will burn up prematurely.
Is the coil labeled 6 or 12 volts??? If you had an ohm meter on the R x 1 scale measure the coils primary resistance between its lil + and - terminals and if its in the 1.25 to under 2 ohms range its a 6 volt coil AND REQUIRES EXTERNAL BALLAST (whether it be wire like FIT mentioned or a ceramic style). If so a typical external ballast needs to be added after the ignition switch and before the coil. The typical white ceramic bathtub style ignition ballast resistors are around 1.5 to 1.85 ohms.
Bottom line is you need a total (coil + any ballast) of around 3 ohms total in the primary ignition circuit to avoid premature point burn up. That can be EITHER a 6 volt coil + a ballast or else a full true 12 volt rated coil which requires no external ballast.
John T
bigblock
06-01-2007 19:04:54
 Re: points in reply to John T, 06-01-2007 18:57:46
The writing on the coil is long gone ,but I will ohm it anyway.The coil would not fire at all,even after I replaced the points.I tried another coil and all is good again.I'll get a resistor saturday and install it,but I'm still unclear on which coil to get.12v for sure,but internal or external resistor?
John T
06-02-2007 05:42:02
 Re: points in reply to bigblock, 06-01-2007 19:04:54
You need a true 12 volt coil which may be labeled "12 Volt" or it may be labeled "12 volt not for use with external ballast" or "12 volt no external ballast required"
HOWEVER DO NOT GET one labeled "12 volt for use with external ballast" or "12 volt external ballast required"
Some people refer to 12 volt coils being "internally ballasted" but most simply use more primary wire or wire having a higher resistance to achieve the near 3 ohms of primary resistance versus and internal discrete balalst resistor inside the coil.
Running a 6 volt coil at 12 volts and not adding any ballast would have overheated and can fry the coil plus cause the points to have burned prematurely.
John T
bigblock
06-01-2007 18:55:22
I'm pretty sure they converted it to 12v.No resistor wire.The wire I replaced was off the ignition switch.But it melted the points.I would have left it 6v,But it now has 12v guages,alt and whatever else.
F-I-T
06-01-2007 18:28:39
I drove a '53 to high school and prided myself on it starting fine and running well on a standard 6 volt battery. To make one start dependably in the dead of winter is a testament to skill. That's why I don't appreciate a 12 volt conversion. If you can't make'm start and run as the original engineer intended, then you're just building a custom rod of sorts.
When they "converted" it, did they perhaps use a piece of "resistor" ni-chrome wire to drop the voltage to the distributor? Maybe that's the wire that melted, and now you replaced it with a regular conductor. Check the voltage going to the coil and if the coil does not have an internal resistor, or is otherwise marked for 12 volt use, get a ceramic dropping resistor (the Mopar ceramic block ones mount the easiest), and check the voltage drop when operating the engine again, as you might have to pad it up or down to get the voltage that you require.....my two cents.
Mike M
06-01-2007 18:14:33
Sounds like someone put in a 12V battery where a 6 volt was to be. Or they did not convert it properly.
