John Deere Model A seats
a42n8brad
06-01-2007 13:19:49
Hello fellow antique tractor fans! Can"t get a good enough picture to figure it out and don"t wanna wait until next tractor show. My "47 has a boxey, padded seat with the battery beneath. I have seen many with a different, unpadded and spring supported seat. Was this an option? When did it start? Where is the battery at on "spring seat" models? Many Thanks, Brad
P Browning
06-01-2007 13:54:49
 Re: John Deere Model A seats in reply to a42n8brad, 06-01-2007 13:19:49
brad -- If you have a 1947 JD-A tractor and do anything mechanical on it -- you should also have a PC 675 Parts Catalog, and in the opening section you will see images of the Model A configurations. The pan seat (the one with a big spring) was standard from the beginning up through A583999 and with A584000 a new tractor emerges with a pressed steel frame and battery under a cushion seat -- no more "long-hood" JD-A tractors! This serial number break came in early 1947 production.
BUTCH GA.
06-01-2007 13:37:04
my fathers John Deere A was a 1946 that had the spring type seat but it also was hand crank at the fly wheel not sure what year they changed
