Electrical problems
Chris Comer
06-01-2007 09:17:27
Hi guys Sorry to waste everyones time I didnt do the gen test right. Started thinking about it so tried again motor DID spin faster. Anyway burnt out on this problem. How could all new stuff not fix this problem. I think there must be a wiring problem farther back in the system. Called John Deere dealer mechanic said could be some wire from ignitian? Anybody have idea here? Also I was putting voltmeter on battery right for tests. But did have backwards on vr bat post, duh. Thank for the help.
Pappy
06-01-2007 22:28:16
 Re: Electrical problems in reply to Chris Comer, 06-01-2007 09:17:27
In your post--you say you looked down and saw it sparking. Where are these sparks coming from--This does not sound normal. If they are coming from the generator, you may have some bad brush contact with the armature.
Bob
06-02-2007 03:02:41
 Re: Electrical problems in reply to Pappy, 06-01-2007 22:28:16
There is visble sparking at the brushes while the generator is charging, even when "all is well".
John T
06-01-2007 11:53:01
If you by passed the VR by dead grounding the Field (and assuming the genny has a good ground, check and insure that) plus had the BAT and ARM terminals tied on the VR, its out of the equation and since the genny passed BOTH of the motor tests it ought to charge, so I reallyyyyy y wonder about a wiring problem now. The voltmeter right on the battery ought to read 12.6 volts setting not running and rise to around 13 to 14.5 or so running at fast RPM IF SHES WIRED RIGHT AND CHARGING. I guess its only a 3 terminal (BAT ARM FLD) VR and NOT a 4 terminal (BAT FLD LOAD with ARM on bottom or side all by itself) ?
Thats about all we can do for ya over the net
John T
chris comer
06-01-2007 15:58:22
 Re: Electrical problems in reply to John T, 06-01-2007 11:53:01
Yes is 3 post VR BAT ARM FLD
Chris Comer
06-01-2007 15:54:36
Thank you to everyone for all the help. I have learned alot. Enjoyed all the great info and printed all to use later. I think it must be a wiring problem/short some were because I mowed wtih today and the gen light went out and I looked down in the gen and I could see it working (sparking). Wish I would have had my voltmeter with me it will be in the tool box next time. Of course it stopped working before I got home to check it out. Probably one little bad wire. Cant thank you guys enough. Take Care Chris Comer
