D is running but
HaroldIHC
05-31-2007 21:06:24
Hi, The D is running but not real good, seems to be floding. I ordered a carb kit for it today. I have one more dumb question to ask. How does the first reduction gear[or spline gear as the parts book names it] get lubrication? Cant find a place to put oil in. Also Glen, yes the front wheels have flat spokes, What does that mean other than it has flat spokes? Thanks again.----- --Harold
Glen_in_TX
06-01-2007 10:13:21
 Re: D is running but in reply to HaroldIHC, 05-31-2007 21:06:24
Harold, The flat spokes just mean you have the right wheels on a 29 D. They only put the flat spoke fronts on 29 Ds some with straight flat and some with angled spokes. If you didn't have the flat spokes they might be hard to find for it. Check the float and make sure it's okay or you might have to try that trick of honing in the needle seat better Duane and others were talking about earlier in other post. I seem to have have better luck with the viton rubber tipped needles in carbs but spray them with WD 40 or silicone and then smash them in hard for a bit to seat them better or could try Duanes vaccuum trick on them. If trans oil level is correct the reduction gear lubrication should take care of itself. It's the LH side quill bearing you have to pour oil into on later D or take cover off to grease bearing on 30 D and earlier when doing stationary belt or PTO work. Some have found on Ds that were changed to tires and had high speed gears put in the oil level was not kept higher for the back gears to pick it up keeping bearings lubricated. So if it's on rubber on rear and goes faster than most Ds you should have noticed smaller gears in rear and should put more oil in so it can flow to all bearings and reduction cover too.
HaroldIHC
06-01-2007 20:56:39
 Re: D is running but in reply to Glen_in_TX, 06-01-2007 10:13:21
Thanks much again Glen. ----- ---Harold
