JD 430 POWER STEERING
DOUG SHAW
05-31-2007 19:03:37
WHERE CAN A GUY GET A POWER STEERING PUMP REBUILT FOR A 430 I BELIEVE ITS A GM PUMP
Henry M
06-01-2007 05:30:11
 By the Way in reply to DOUG SHAW, 05-31-2007 19:03:37
The fog is clearing a litle. It seems that the only book that JD published that gave a good run down on that pump was the 440 service manual. JR Hobbs gave me that tip.
Henry M
06-01-2007 05:27:58
 Re: JD 430 POWER STEERING in reply to DOUG SHAW, 05-31-2007 19:03:37
Doug
Last time I tried to get the rebuild kit jd was out of stock and I could not locate a NOS one.
I would do what bigblock says and run a pressure test on it first, your probs may be elsewhere. Also you did not say what is the problem. Last time i was able to get all the periphial stuff like seals and gaskets except one small one on the rear of the pump.
As I foggily recall, I bobught a high pressure hyd guage at the farm store for around 12 to 15 bucks and t'ed it right into the pressure line for the test.
DOUG SHAW
06-01-2007 16:01:30
 Re: JD 430 POWER STEERING in reply to Henry M, 06-01-2007 05:27:58
IT WILL PUMP THE OIL BUT WONT CREATE ANY PRESSURE AND WONT HELP STEERE NAPA SENT IT AWAY TO SOMEONE THEY HAVE REBUILD PUMPS MAYBE THEY CAN HELP THANKS FOR YOUR INFO. DOUG
bigblock
05-31-2007 19:13:15
Is it leaking or low pressure or stuck?
DOUG SHAW
06-01-2007 16:05:52
 Re: JD 430 POWER STEERING in reply to bigblock, 05-31-2007 19:13:15
VERY LOW PRESSURE DID LEAK SO WE PUT NEW O-RINGS IN IT AND NOW NO LEAKS OR PRESSURE NAPA SENT IT OUT TO SEE IF THEY CAN GET IT REBUILT THANKS DOUG
