38B UPPER WATER PIPE
flyingjd
05-31-2007 11:10:20
I have dissambled my 38b to fix an oil leak under the governor and while there removed upper water pipe and found many pin holes that had been fixed with clear rtv. I need to find out the best solution for replacing this upper pipe and is there any way to clean out the rust and debris from inside the cylinder assy without tearing the whole engine apart. This tractor had sat for a very long time and had anti freeze but is very rusty inside. Any help would be appreciated. THANKS
bigblock
05-31-2007 18:55:13
 Re: 38B UPPER WATER PIPE in reply to flyingjd, 05-31-2007 11:10:20
I took my old rusted pipes to my local muffler shop and he cut some brand new ones.He had to expand one slightly.Also they are twice as thick as the old ones.
Mike M
05-31-2007 11:39:58
K & K Antique tractor sells some of those upper pipes (among other stuff you may need ) so I'd check with them about a replacement.
I'd flush out the loose rust best you can with with a hose and not get to carried away for fear of loosening up too much and causing a hole to open up in a casting. I've heard of a couple of those unstyled B's with holes rusted through the bottom of the block so they must be kinda thin.
