2120 john deere hi low
mbd41
05-31-2007 09:34:26
I have a 2120 that the hi low clutch assembly is shot on. Does anyone know of a used assembly.
mbd41
05-31-2007 11:40:48
 Re: 2120 john deere hi low in reply to mbd41, 05-31-2007 09:34:26
before we got the tractor - the previous owner felt it was not worth having and welded pieces together to allow it to only work in low range. I am trying to see if its worth returning to the original state.
buickanddeere
05-31-2007 18:28:59
 Re: 2120 john deere hi low in reply to mbd41, 05-31-2007 11:40:48
Might be time to sell the tractor. If the clutches are out of the high/low. The brakes can't be much better. If memory serves the hydraulic controled independent pto wasn't a 20 series option. So no worreis there. If a non wet clutch oil is used in the trans/hydraulics. The fiber disks soften, flake off and plug the screen & filter. Then as metal to metal contact occurs. Shinny metal shavings start plugging the screen/filter as well. Given the previous owners maintaince methods. Just about everything else will be "farmer fixed" on the tractor as well. Odds are the anti corrosion additives are long gone from the anti-freeze. Sleeve pitting & water leaks will follow.
Tx Jim
06-01-2007 05:22:52
 independent pto available in reply to buickanddeere, 05-31-2007 18:28:59
buickanddeere,according to JDPARTS 2120's could have independent pto! As for hyd hi-lo going south barring tractor not having had wrong oil installed it could have been caused by a cracked/broken supply tube to hi-lo or a leaking sealing ring for hi-lo with nothing wrong with brakes. Tx Jim
buickanddeere
06-01-2007 10:28:25
 Re: independent pto available in reply to Tx Jim, 06-01-2007 05:22:52
Tx Jim
You are correct. Around here the two stage clutch was the norm with the 20 & 30 series Dubuque & Mannheim tractors.The independent pto seemed more popular into the 40 series and later. I wonder why? I was thinking if the wrong oil had been used in the trans/hydraulics and ruined the high/low clutches. Then that same wrong oil would be destroying the brakes. As you say a failed high/low on it's own should have little to no effect on the brakes depending on the type of failure. Given the age of the tractor and cost of repairs. The money would be better spent on something 20 years newer and in better condition.
buickanddeere
05-31-2007 10:36:48
How was the decission made that the high/low is shot?
