The charging system is not grounded. A better voltage check is across both batteries and should be in the 28 volt range while charging. No rise when it should be charging is a hint of it not charging. 12 volts isn't all that bad under load but in the 24 volt system that doesn't tell what the other battery is seeing. There have been slip on or clamp on DC ammeters. One that I have came from Sears for a few bucks and it just sits next to a wire and shows charging current. Its a tool I'd grab if I was testing your charging system.
As noted by another post, the 24 volt regulator is not grounded but it requires what would have been ground to be connected to the other side of the floating charging circuit. The starter, battery, and generator with its regulator float, but the center of the battery is grounded. That makes up the 24 volt system (one tenth the voltage of a 120/240 volt DC system that Edison used 125 years ago). Lighting loads are split between the two sides evenly if done right with half the lights running on the +12 half and the other half on the -12 half. If the generator is good, the brushes not worn short, the pulley and belt are good then its either a wiring or a voltage regulator problem I think. The electromechanical regulators do wear out. Some times you can take the cover off and polish the burned contacts (with both batteries disconnected) but that's at best a short term patch and the wearing of the contacts will have changed the regulating voltage a lot. I barely paid more for my three wire alternator that the Deere price for a 12 volt regulator and I expect the 24 volt regulator to be more pricey probably $50 but their conversion kit was $600 on sale a couple years ago. Gerald J.
