Cylinder head replacement on JD 620
hiker
05-30-2007 19:51:57
I just got the cylinder head cracks repaired. The head and new gasket is in place. Can anyone provide the torque (150 lb?) and pattern (start inside, then clockwise outside?).
Thanks,
Brad
CLW
05-31-2007 06:53:49
 Re: Cylinder head replacement on JD 620 in reply to hiker, 05-30-2007 19:51:57
My I&T manual says "Using new lead washers under the stud nuts, install the nuts and tighten them progressively from center outword and to a torque of 150 ft.-lbs. After engine is hot, re-tighten head nuts to specified torque value and adjust the tappet gap to 0.020 hot."
MPK
05-30-2007 20:08:15
Yes, the cylinder head torque for the 620 is 150 FT lbs.
