H Carburetor
Cannon
05-30-2007 18:02:01
I wonder if anyone can tell me why I am having trouble with the needle valve in my H Carburetor. I put a new valve and seat in it, have it exactly where the height should be, and still it allows gasoline to flow through and into the cylinders. Any suggestions?
Glen_in_TX
05-31-2007 12:07:52
 Re: H Carburetor in reply to Cannon, 05-30-2007 18:02:01
I never understood why or heard a explanation yet but both the H carbs DLTX-26 & 46 show to have used different needle sets and floats than the other DLTX carbs. Should be AR10034R needle set and AR10067R float. So make sure you have the correct float and needle set for it. Some of the fits all kit parts don't work well on some. If the float is collapsed any at all replace it. Make sure pivot pin and bushings are not worn bad or it is bent dragging on side of carb bowl too. You might have better luck with the viton tipped needle set too but we even have trouble with them seating on other brand carbs too. Think it is just our gas today and you need to shut off the sediment bowl when not using it.
Mike M
06-01-2007 10:46:56
 Re: H Carburetor in reply to Glen_in_TX, 05-31-2007 12:07:52
Glenn; the H carbs. have a small round stamped metal bowl similar to the ones on like a 620 type carb ( gaskets will interchange ) and not the large cast type. So the float is smaller and so is the needle valve. The needle valve for an H is the same as in the 620 type and carbs. and like a model M also use ( tsx ? carb. )
Mike M
05-31-2007 04:53:34
In addition to all the other good ideas. Those can also leak at the gasket where it threads in if the gasket or casting is not a good fit. The seats can also be machined wrong on the outside causing it to bind up before it gets tight , but this is mainly on the A and B style carbs.
dds-inc
05-30-2007 19:54:42
hole in float. shake it. you might feel some sloshing around. What else could it be except for very dirty fuel?
P Browning
05-30-2007 18:58:47
Cannon -- failure of this valve to close can be a result of several factors. Float level setting is one, a leaking float that is taking in fuel and thus losses its ability to float another, debris (it don't take much) is yet another. Of course, I am assuming here that the seat and needle are a good match. Look also for possible binding at the float hinge. The hinge pin must be straight & smooth. Having the pin centered can be helpful too.
Now assuming all is done just right in terms of a good valve, healthy float and a hinge with near-zero friction, some of these valves can require a day's hard work in the field to "seat in". This was a suggestion from Deere Service men as far back as the early 40's.
Now for specifics -- the float level setting for the JD-H tractor is that the needle valve closes with the float 3/8" from the casting. If the carburetor were off the tractor & you held it exactly upside-down, correct float closure would come with the float dead level. All of this criteria leads to a float setting that sustains fuel at 3/4-inch down from the top of the bowl. The test set up F-I-T mentioned is illustrated on the JD-H Restoration Site (below). On the home page, scroll down to item # 8. Click on that selection to obtain a visual of the clear hose with hose barb tool used for measuring float performance. You do not have to buy anything to go there and learn. (PatB)
Duane Larson
05-30-2007 18:54:35
Cannon,
For the last 7-8 years I have had problems with aftermarket needle and seats. I've rebuilt carburetors and magnetos for better than 25 years and about 30% of the currently available aftermarket needle/seats I have to work on to get to hold fuel. Prior to putting in a n/s I have built adapters to pull a vacuum on the n/s, and the bad ones leak to zero in less than 20 sec, while the good ones will hold a good vacuum at least overnight. There are two things to try: 1) put the seat upside down, put the needle in it, and give the needle a tap with a hammer - that will sometimes work, or 2) if you have access to a small lathe and some aluminum oxide polishing compound, make a paste of water/aluminum oxide, apply to the needle, and spin the seat keeping light pressure on the needle. Most of the time that will provide a good seat - but some of them just will not stop leaking. Don't use valve grinding compound as that is too coarse.
An alternative is to get a viton tipped needle/seat - if you have a clean tank, clean fuel, and a clean fuel can, they work pretty well, but are higher priced.
dan hill
06-11-2007 03:49:48
 Re: H Carburetor in reply to Duane Larson, 05-30-2007 18:54:35
The viton tip needle valve sticks shut often.Small engines with a soft seat give trouble with sticking shut.
teddy52food
05-30-2007 20:35:35
I have used toothpaste to polish them in. Seems to help.
F-I-T
05-30-2007 20:02:45
Duane:
What grit A/O do you use to polish the needles with? Back in the day, when I had to polish hydraulic needles and poppets, we used some pretty fine stuff, like rough with 600 or 800, and a final of 1200, and we smeared it into a piece of leather "strop" using mink oil as the base. It lasted forever, and it gave a mirror polish to alimunum. We used silicon carbide at similar grits for stainless. Just wondered how fine a grit you use. FYI, I polish mine as well. There seem to be some with micro parting lines since they began to die cast them in stead of machining them.
I remember if you spit on the backside of the plain leather, and touched it would go to mirror finish in short order after the 1200 polish. It hads to be less than a 3 micro.
Frank
Duane Larson
05-31-2007 07:38:14
 Re: H Carburetor in reply to F-I-T, 05-30-2007 20:02:45
Frank,
A fellow at a ceramic polishing operation gave me some white powder in a plastic bag labeled 95-135 alumina polishing compound. It feels like talcum powder. I can try to get more info, but he gave me about 10 lifetime supplies - I mix with a couple drops of water (can be hard to mix initially as the water just balls up and rolls around - tremendous surface tension) to form a paste.
Regards,
Duane
F-I-T
05-31-2007 07:44:02
 Re: H Carburetor in reply to Duane Larson, 05-31-2007 07:38:14
I gotcha. I have some "Alumina" that is the consistency of talc, and I got it when I bought a kit for polishing car window glass from Eastwood. The container has enough to do a lot of glass. I might try that on a old needle or two and see how that works. It sure as heck cuts glass well!
F-I-T
05-30-2007 18:14:45
Check the float for a pin hole? Submerge the float in hot water and as the air in the float expands, it will bubble out any hole or crack. Also shake it for any sign of fuel within. Maybe use a stand tube to see where the fuel level really is ( a brabed fitting in place of the fuel bowl drain cock and piece of aquarium tubing held upright. Works as like a water level. It's easy to have the float seem to be right, but the fuel level is still too high.
Frank
