4240 - pto will not stay engaged
mbd41
05-30-2007 12:45:38
Pto will not stay engaged. If held up it stays on but upon release of the arm it falls and disengages pto drive. What is the problem and is it an easy fix? thanks
G/MAN
05-30-2007 16:14:09
 Re: 4240 - pto will not stay engaged in reply to mbd41, 05-30-2007 12:45:38
Before you go replacing anything, give the clutch valve area a good look-see and cleaning, especially if the tractor is a PowerShift model. It's not uncommon for dirt and debris to build up there and keep the PTO-control linkage from engaging fully and locking in. On PowerShifts, It's also possible for the retaining nut to come loose and the lower arm to work loose on the valve operating shaft and cause engagement issues. If that's the case, usually the nut can be tightened or replaced without further disassembly, although they can be a little challenge to get to.
donmyeil
05-30-2007 12:54:25
Under the left cab mount is the clutch valve housing. You need to remove it and replace the pto arm that is bent. It's a pot metal arm that is held engaged by hyd. pressure. Very common on 30 series . This is assuming you have suffecient transmission pressure .
