4030 overheating
Brad Moody
05-30-2007 09:08:19
Replaced head gasket on my 4030 diesel because I was getting antifreeze in my oil and was overheating. Headgasket looked ok, got the head reworked and thought all was well. Now I'm getting antifreeze in my oil again but not while its running, only after it sits overnight. Does anyone have an idea what else could be leading to me getting antifreeze in my oil. I don't think it's a cracked block because she runs just fine.
Mike M
05-30-2007 10:00:29
 Re: 4030 overheating in reply to Brad Moody, 05-30-2007 09:08:19
sounds like liner pitting. Pull off the oil pan and pressurise the rad.or just wait overnight and look for drips around the sleeves.
WTW
05-30-2007 09:51:44
Brad, The 329 Dubuque built engine used in the 4030 was very prone to have a liners cavitate and burn a hole through sleeve (Electrolysis). Depending on location of hole in sleeve it may pressurize radiator when running. Depending on location of piston in sleeve when engine is shut off it may leak a little or a lot of coolant in oil as hole in sleeve is usually near bottom of ring travel. Just as well pull the pan and let set over a cardboard to see where water is coming from. If running from inside diameter of sleeve you got a hole burnt through it, if leaking on outside diameter of sleeve you have a packing leaking around liner. If it is like most 329/4030 engines just as well plan on a sleeve and piston overhaul kit to fix problem. DW
Brad Moody
05-30-2007 12:12:12
 Re: 4030 overheating in reply to WTW, 05-30-2007 09:51:44
Thanks guys, I was really hoping for a less expensive repair then this like the radiator or oil cooler but I'll take your suggestions and run with it. Thanks again!
One more question, shouldn't it be running rough if it has one or more sleaves leaking?
G/MAN
05-30-2007 16:23:44
 Re: 4030 overheating in reply to Brad Moody, 05-30-2007 12:12:12
The oil cooler is commonly and the vast majority of the time incorrectly suspected, as cooler failures are very rare and will just about always result in oil in the coolant and not vice-versa, as the oil pressure in the cooler with the engine running is far higher than the cooling system pressure and oil will be pushed into the coolant and not the other way around.
Mike M
05-30-2007 12:17:22
Those sleeves will leak and not effect anything else until the antifreeze in the oil eats up the bearings and locks it up.
