 I'm presuming that when you say "lift" that you have a Powr-Trol unit, as opposed to a Powr-Lift. The Powr-Trol option was very much the more often selected hydraulic lift option. The book says to use the same weight and grade of engine oil that you have in the motor at the time. Some folks claim non-detergent foams less, and other use modern Hy-Tran or equivalent, but I have alweays just added oil from my oil-for-the engines-stock. There should be a filler cap on the top rear edge capping a pipe plug (large red circle). Without an operator's manual in hand, which I recommend that you get, you can just add oil, pto engaged, clutch engaged, until the lift goes up and stops, adding oil until the lever kicks out. That's the day-on-the-farm-method. There is also a check cock on the right side small red circle) that you can open and fill until it runs out. All this is detailed in the book. As soon as you get one, you'll find all manner of information in there that will be helpful. Frank
