JD 2440 ONLY HAS PRESSURE TO ONE SIDE OF HYDRAULIC
LYNN HOBBS
05-29-2007 18:20:38
I have an early model 2440 that has Hydraulic problems. I am only getting pressure to one side of my Hydraulic breakaway couplers. The hydraulic lever only sends pressure to the one side when it is pulled back. I am unable to operate double acting cylinders. Any help would be appreciated.
Tx Jim
05-30-2007 03:51:15
 Re: JD 2440 ONLY HAS PRESSURE TO ONE SIDE OF HYDRA in reply to LYNN HOBBS, 05-29-2007 18:20:38
As mentioned,it could be faulty coupler! Hyd tip ball worn or valves need adjusting or replaced inside of control valve. There are two pressure and two return valves that are not easy for a novice to adjust. Are you flipping both levers underneath coupler to turn on oil after coupling hoses? Tx Jim
LYNN HOBBS
05-29-2007 21:13:19
I don't have any pressure to either coupler when the lever is pushed forward. I guess I should have added that. I figured it would be a given That if only had pressure when I pulled the lever back and that I was having hydraulic problem that I didn't have anything when it is pushed forward. Sorry for overlooking this.
MSM
05-30-2007 13:20:37
 Re: JD 2440 ONLY HAS PRESSURE TO ONE SIDE OF HYDRA in reply to LYNN HOBBS, 05-29-2007 21:13:19
If you go too far foward,it goes into float.
dds-inc
05-29-2007 18:53:00
maybe your quick couplers are not functioning well.
flying belgian
05-29-2007 18:40:31
It is only suppose to send oil to one side when you pull lever back. The other side is for oil to return to tractor from double acting cylinder.
