>>>the noise is there anytime the engine is running: pto in/out, clutch in/out, and in gear or out...I put a prybar under the flywheel and there is quite a bit of "up/down" movement, perhaps .035 to .050 ...>>> No matter what it is, that is a lot of bearing play given that it ought to be in the range of .007 or so. Tell me what sort of hours on the tractor since its last major overhaul. Play like that is going to have to be taken care of eventually even if it is not the cause of this noise. >>>I'm in the process of taking the flywheel off...The last person has apparently put it on with JB weld so it has been a pain to say the least...>>> THAT really makes me feel good about the condition of your engine. Let's ponder this. "Should I fix it right, or put some epoxy glue on the crank splines so the next guy can deal with it".....If I were you I would not look forward to a quick diagnosis and repair. If you really like this tractor, I bet you will find much more out of service limit problems as you go deeper, based on the previous owner's level of repair. How long have you been running this engine under real work conditions? >>>I had to cut the 'stamped nut' off...>>> Those can be a bit pricey (just a warning), so I would have recommended that you heat it with nothing more than propane to soften the goo and grab it with the pipe wrench, or my favorite, my 36" Channel-Lock pliers. They alays come off for me that way. It is only used to push and hold the flyhweel inward until you get the bolts clamped down on to the crank shaft. >>>the flywheel is just about ready to come off - got to get the engine lift hooked up to it now. As yet I have not seen any 'shavings' etc except a piece of clutch disc or two but after removing the clutch and all the plates from the pulley the noise still exists...>>> It could even be something as innocuous as a tin oil shield inside the first reduction cover that is rubbing. Before you go so far as to render the engine inoperable, try a piece of garden hose as a stethoscope to try and figure out which side the noise is coming from. You know there is also a tin shield that is located behind the flywheel to seal the pony area and flywheel cover. No chance that it got bent and is rubbing? That can sound pretty awful. One last thing, when you say same noise pto in or out, do you mean whether the pto lever is engaged or out? You can only put that in gear when the engine is stopped but you can "kick " them out while they are running for a test. This is different than the live pto clutch lever by the battery box. What EXACTLY were you doing the moment that the noise began? and that could be "Just driving along, running the baler,minding my own business"..... Frank
