JD 730 D question
JD Tractor Boy
01-11-2000 17:14:43
third party image
Hi,
I was driving a friends 730D elec start and saw a red light on the dash. I know that this light indicated oil pressure on the pony motor on pony motor start tractors. My question is, what is it for on a elec start diesel?
thanks
chaz
aka "Tractor Boy"
Tim H
01-11-2000 17:58:07
 Re: JD 730 D question in reply to JD Tractor Boy (Chuck McDonald), 01-11-2000 17:14:43
The 730 (electric start diesel) has dash panel lamps in the top center of both the upper and lower dash panels. These lamps iluminate the dash panels when the headlamps/worklamps are on. Also, there is a lamp on the upper dash, to one side, that the 730 parts book lists as "Light, Indicator, Generator" With only Fuel, Temp., and Oil Pressure guages, perhaps this lamp indicates if the generator is charging or not.
Doug
01-11-2000 17:42:13
When that red light is on your gen is not charging, Check your generator an regulater out,it 's an 24 volt system.
