2940 Tie Rod ends
Frank radford
05-29-2007 17:14:25
I have a 2940 which has bad tie rod ends and would like to know where i could get replacements. The tractor is a 2wd and tie rod ends use a pin that drops through the steering arm. So far i have only been able to locate them from JD at over $500. I have found the left one aftermarket for around $50, but to get the rightside you have to by the complete tie rod from JD. Please any help or ideas.
HTR
05-30-2007 17:18:49
 Re: 2940 Tie Rod ends in reply to Frank radford, 05-29-2007 17:14:25
Buy two of the short ends, cut the round end off of the old long rod, and one of the new short ends. If you are a good welder, weld the new round part to the long rod. If you have doubts, get a good welder to do it.
Frank Radford
05-30-2007 13:25:38
These are not the same tie rod ends that are on American made tractors, they have no rubber boots. Its a medal ring that a pin drops through into the steering arm.
JD2120 Yes i would like a price quote for left and right tie rod ends. This is for a 2wd, single steering cylinder, JD2940.
Frank Radford
05-30-2007 13:42:34
 Re: 2940 Tie Rod ends in reply to Frank Radford, 05-30-2007 13:25:38
Heres a link to the JD parts index so you know what it looks like. Both sides have this type end
Link
jd2120
05-30-2007 13:34:30
hey frank, open up your e-mail or send me an e-mail and i'll get you the price on them.
Glen_in_TX
05-30-2007 09:19:27
They probably sell them right here on YT as do many other aftermarket vendors. We can sell them to you for less than JD or A&I and they are the same thing I understand. Any local TISCO dealer can get them for you too.
jd2120
05-30-2007 09:01:15
hey frank, i'm a dealer through A&I and can get you tie rod ends at a good price, A&I makes the tie rods for deere, plus theirs have a grease fitting on it, reply back if you want a price quote
Dave Sherburne NY
05-29-2007 18:15:01
I replaced all of them on a 2640 a couple of years ago, and I got them all from an A&I dealer. Where are you located? I checked on this site, and couldn't find them.
