John Deere STX 38- Blades wont stay engaged
Josh Joyce
05-29-2007 15:54:49
I bought a used STX 38 a few weeks ago. The mower runs great and has been really well cared for. I had a problem today with the blade deck.
After cutting for the first 15 feet the blades would keep disengaging-engaging (it would be disengaged for about half a second at a time) over and over again. I adjusted my weight on the seat, but no change. Then I shut off the blades and tried to turn them back on again. They wouldn't start up. I repeated this a dozen time then finanly they did start up, but would disengage-engage again. Any suggestions?- thanks! Josh
Josh Joyce
05-30-2007 08:34:06
 Re: John Deere STX 38- Blades wont stay engaged in reply to Josh Joyce, 05-29-2007 15:54:49
Thanks DeereJunkie,
Turns out to be the wiring for the PTO. The bolt that holds the ground to the frame was only held on by a couple of threads. Cleaned it up really well and now shes like new again. Thanks again.
Josh
DEEREJUNKIE
05-29-2007 16:23:08
CHECK THE SEAT SWITCH WIRING, YOU CAN JUMPER AROUND THE SWITCH ITSELF, CHECK THE PTO SWITCH WIRING , I T COULD BE A FAULTY SWITCH, CICUIT BREAKER OR WORSE OF ALL THE CLUTCH WHICH CAN ALSO BE OUT OF ADJUSTMENT BUT THE SAFETY CIRCUIT WOULD BE MY SUSPECT, GOOD LUCK
