830 leaking steering shaft
JDGMC
05-29-2007 13:54:53
The steering shaft below the power steering unit is leaking bad. This is the shaft that the steering arm is connected to. Until I looked at the parts manual, I thought it would be a simple seal replacement. Now, it appears that I have to take the steering unit apart to get at the seal. Anyone have any insight into the scope of work this will take???
Thanks for any responses,
Wes
Glen_in_TX
05-30-2007 11:55:48
 Re: 830 leaking steering shaft in reply to JDGMC, 05-29-2007 13:54:53
Hood, dash and other things have to come off to get to pulling steering valve assembly off tractor. Instead of just a I&T you'll find much better service info in the JD manuals SM2050 Power Steering service manual that covers 80,820 & 830 power steering component service and rebuild plus covers other 2 cylinders with power steering as well. The SM2021 service manual that covers 80,820,830 & 840 tractors. There is also a SM2022 Hydraulics for custom powertrol. JD publications 1-800-522-7448.
Tx Jim
05-30-2007 04:10:01
To correctly repair you have to remove steering valve and totally disassemble it to install quad ring. The worst part is R&R o-rings inside of housing as I think there's 6 of them if my memory is correct. Tx Jim
