2240 brake problem
Stonecreek
05-29-2007 13:31:48
The left brake on my recently-acquired 2240 isn't functional. The pedal goes fully forward with little resistance (I do detect the slightest hint of braking, but it is minimal and quickly disappears). I have bled the brake line as instructed in the owners manual, but this didn't help.
The right brake is fully functional when used alone. However, if BOTH brake pedals are pressed simultaneously, then both brakes lose pressure and braking function. I have the Tech Manual, but its descriptions don't seem to cover this scenario.
All advice appreciated.
720 in pa
05-30-2007 03:51:26
 Re: 2240 brake problem in reply to Stonecreek, 05-29-2007 13:31:48
the two sides are connected only when both pedals are pushed simaltaneously.when you push only one pedal,it only actuates its respective brake.when both pedals are pushed,oil is allowed to equalize between the two brakes.the reason for this is to keep brake pressure even to both sides when pedals are pushed.if after plugging the line as stated above,should tell if the problem is in the axle
720 in pa
05-29-2007 13:51:41
sounds like the brake piston seals are blown on the left side.to confirm this,remove brake line from left brake,plug it,and push left brake pedal.if it goes against,brake piston seals are bad.if it goes to the floor,there is a problem in brake valve
Stonecreek
05-29-2007 19:22:08
 Re: 2240 brake problem in reply to 720 in pa, 05-29-2007 13:51:41
Thanks for the suggestion, 720. I read that test in the TM, however there was no reference to one brake being good when used alone, but losing pedal pressure when applied at the same time as the bad brake. That leads me to believe it is a problem inside the brake actuator, but I'm not sure how the two sides are connected.
Tx Jim
05-30-2007 04:18:15
 Re: 2240 brake problem in reply to Stonecreek, 05-29-2007 19:22:08
Stonecreek,there is an equalizing valve between both sides of valve so that when one is pressing on both pedals if brakes are functioning properly tractor will stop straight. As previosly stated cap off line to determine where problem lies. Tx Jim
