The starter isn't affected by battery polarity. The coil isn't damaged by reversed polarity, but it may not produce as strong a spark when reversed. The gas gauges sometimes work less well with reversed polarity. It was shipped positive ground. If only the battery was changed (and the generator flashed after the change) it will work, but it would work better if the coil primary terminals were swapped so the plus terminal goes to the ignition switch instead of the points in the distributor. There probably is a resistor on the coil primary too, either a resistive wire or in the ignition switch and that is shorted out by an auxiliary contact on the starter solenoid to improve ignition while starting. The original generator is only 20 amps and when that works right it can take an hour to make up for a tough start. My gas 4020 now has an alternator and an ammeter so I can tell how its doing and it takes only a few minutes to charge the battery back up after a start. The coil primary terminals should be labeled. The battery posts are labeled. Nothing else cares much about polarity other than the radio if it has one. Gerald J.
