720 Question
Raysflhs
05-29-2007 11:37:38
Finally got the 1958 JD720 I bought in 2005 restored and back together. First reduction gear cover question. Operators manual (SN 7214900 and up) calls for 1.5 quarts of gear oil added through the filler plug behind clutch lever. But my tractor has no filler plug. Reading through the maintenance manual shows that the clutch design changed a few times during the 70/720 production. SN is 7225772 - it has plates on top and bottom for clutch fork adjustments. I�m assuming you add 1.5 quarts of gear oil through the top plate opening � is this correct? Thanks
2cylinderlp
05-29-2007 17:00:13
 Re: 720 Question in reply to Raysflhs, 05-29-2007 11:37:38
I pulled the pulley brake off and then pulled the pin that pushes on the pulley brake. Then I used a big syringe like you can get at auto parts stores to shoot it in there.
bigblock
05-29-2007 15:07:56
That is correct.It's identical to my 730.
Mike M
05-29-2007 12:23:14
If you have the rectangler plates remove the top one and fill it there.
You can also fill them if you happen to have the pulley off before you put it back on just pour the oil to the backside of the divder if I remember right ?
