2040 hydraulics
Rogen
05-29-2007 11:17:46
I own a 1982 2040, I would like to fit it with hydraulic remotes (2) Rear and whatever it takes to fit with a loader. Could someone please tell me what I need. Is power steering pump same as remote hydraulic pump? Thanks.
720 in pa
05-29-2007 13:03:41
 Re: 2040 hydraulics in reply to Rogen, 05-29-2007 11:17:46
power steering pump is the same as remote.you will need either two single or one double closed center valve,flow rating depending on what you want to operate with remotes.
on right hand side of tractor below floorboard towards the rear of tractor from brake valve there is a small three bolt valve.the plug in this valve facing to rear of tractor is where you want to get the pressure for remotes.
the return should be run into hyd. filter cover.if your cover does not have a hole in the side to run a line in,i would reccomend getting one. good luck
Rogen
05-30-2007 05:46:38
 Re: 2040 hydraulics in reply to 720 in pa, 05-29-2007 13:03:41
720 in PA, thanx for the input, that should get me on my way.
