72 4020 front hydralic pump
wendell minneso
05-29-2007 10:12:14
my front hydralic pump on my 4020 leeks. My JD dealer says I must rebuild the pump to the tune of $700. I use this tractor on 400+ acres and wonder if I can get by with just bearings and seals. I have had these rebuilt before and do not look forward to removing and replacing this beast. This is my big tractor along side a 70' 4020 and a 72' 3020. The little peach has about 13000 hours, looks great, and I wouldn't think of selling it, but money is an issue right now.
Bob
05-29-2007 20:36:29
 Re: 72 4020 front hydralic pump in reply to wendell minnesota, 05-29-2007 10:12:14
Have you determined EXACTLY where it is leaking?
flying belgian
05-29-2007 18:52:30
Not true what your dealer says. I had dealer replace all o-rings in mine 4 weeks ago to stop all leaks. Ran it about 20 hrs. and had dealer come back no charge to replace a blown o-ring that he said he put in new last time. Ran it another 5 hrs. and had him come back to relace another one that he claims he replaced 1st. time. I don't know whats going on with that thing.
Gerald J.
05-29-2007 13:40:17
The 4020 pump is known to sometimes crack the case. Then o-rings won't fix it.
If you shop around at salvage yards and vendors of rebuilt tractor parts, you may find a better price than your Deere dealer's.
Getting down to it is a pain from what I've read and seen. So far mine isn't leaking.
Gerald J.
m sb
05-29-2007 21:40:12
 Re: 72 4020 front hydralic pump in reply to Gerald J., 05-29-2007 13:40:17
Gerald you are so right on and they usually crack in one or more of the piston plug holes. look for a line in the threaads. That is a tell tale sign of a cracked pump housing.
