5000 series fuel shutoff
cxlvi
05-29-2007 09:03:36
I"ve encountered problems with electric fuel shutoff on both 5310 and 5400. Now, 5400 won"t shutoff with key. All fuses are good, won"t even shutdown if power disconnected. Is this a common problem with newer machines. Local Deere dealer unfortunately not interested in much other than lawnmowers, says never heard of such a problem.
Joe M(GA)
05-29-2007 17:42:36
 Re: 5000 series fuel shutoff in reply to cxlvi, 05-29-2007 09:03:36
Several years ago there was a good amount of trouble, here's you some reading--
PROBLEM: All tractors have higher than expected fuel shut-off solenoid failure due to manufacturing problems with plastic bobbin that the wires connect around. Tractors within a known serial number range are suspect. ADDITIONAL INFORMATION: Another way to identify suspect solenoids is as follows; Before installing new solenoid, check for 'Lucas/Cav' manufacturing code rather than 'Roto-Diesel' Solenoids can be identified by a four (4) digit code stamped on the body. First two (2) digits indicate week number and last two (2) are the year. For example; Code 1594 means week number 15 (11-16 April) of 1994. Do NOT use any solenoid with manufacturing codes from 1293 (22-27 MAR 93) up to 2694 (27 JUN - 02 JUL 94). Any parts with single upright stud are probably 'Roto-Diesel' and should not be used. Unpainted pieces will say 'Roto-Diesel' on top cover near stud. 'Lucas/Cav' pieces have flat top with threaded hole.
