112 won't start
Dick Dillman
05-29-2007 08:52:45
Ill make this long story as short as I can-My grandson's mower has been o'hauled- bored-piston sized, and the starter wouldn't turn it over. Installed a new starter-started a few times, and runs ok when started. Mowed 3 or 4 lawns, now the new starter won't turn it. Replaced new battery, and fully charged it, but it won't turn the engine. Have replaced the switch, coil, points, plug, and wire, so everything electric is new. It will turn over fine with plug out.
Any help would really be appreciated. Dick
Bob
05-29-2007 09:04:35
 Re: 112 won't start in reply to Dick Dillman, 05-29-2007 08:52:45
Kohler engine? (I can't remember, offhand, which models had a Tecumseh as an option.) If so, it sounds like the ACR (Automatic compression Release) isn't working. "Loose" valve settings can cause this, too.
Manual linked below. ACR is on Page # 95.
DickDillman
05-29-2007 10:47:05
 Re: 112 won't start in reply to Bob, 05-29-2007 09:04:35
That is a Kohler engine. Thanks so much for the advice. I am going to try and loosen them up. Dick
Dick Dillman
05-30-2007 07:13:29
 Re: 112 won't start in reply to DickDillman, 05-29-2007 10:47:05
Bob; I didn't mean loosen the valves, I meant loosen the ACR's if they are stuck, and not working properly.
Bob
05-29-2007 20:38:58
LOOSE valve settings will cause the problem you are having! DON'T loosen them MORE!
