4020 engine stuck
wendell minneso
05-28-2007 23:34:58
I've been ill for the past two years. My 72 4020 sat outside with the hood off for a radiator repair. Water got into the engine through the rubber gasket between the intake manifold and the intake pipe that goes over the radiator. Any way now the engine is stuck, I removed the intake manifold and filled the head with wd-40 how long should I wait and how rough do I dare get when rocking it back and forth. Or should I just pull the head
DGK
05-29-2007 19:24:40
 Re: 4020 engine stuck in reply to wendell minnesota, 05-28-2007 23:34:58
Remove injectors blow any water out of cylinders, fill with diesel fuel, If you have a block heater plug it in for a couple days. Heat will do more good than anything. Good luck Doug
billde
05-29-2007 05:25:57
Pull your injectors, good time to have them pressure checked, blow out any water. If it still won't turn over pour transmission fluid in the cylinders let soak a few days and try again.
zwr
05-29-2007 04:18:30
If much water got in, it could be hydraulic lock. Try removing the injectors and then rock the tractor in a lower gear.
