70 Overhaul Cheap-NOT
super99
05-28-2007 16:30:44
third party image
Started tearing down 70 gas to overhaul last winter, Hopeing to get by cheap. A friend ground the valves for me for free. This is going alright, now to get the pistons out and see about rings. Got the pistons out today, top ring groove is burned out on both pistons. Hope I can get picture to work. Doubt there is any saving pistons. Put plasticguage on rods before removal. .004 on both bearings.I need to find a mic to check bore in block. Anyone know of a cheap place to get pistons? Checked on back of rod inserts to see if size wqas marked on them but all it had was f m f1048 1 70
Ready for any and all advise. Thanks, Chris
bigblock
05-29-2007 18:04:51
 Re: 70 Overhaul Cheap-NOT in reply to super99, 05-28-2007 16:30:44
Looks like it took a 250 horse shot of nitrous with no extra fuel!Dont ask me how I know.
bigblock
05-29-2007 18:06:29
 Re: 70 Overhaul Cheap-NOT in reply to bigblock, 05-29-2007 18:04:51
By the way,what is the ring gap supposed to be on a 6 inch bore?
F-I-T
05-29-2007 19:16:51
 Re: 70 Overhaul Cheap-NOT in reply to bigblock, 05-29-2007 18:06:29
I always used the thumbnail of .003-.004" per inch of bore. That's the standard that Hastings publishes.
Frank
buickanddeere
05-29-2007 11:11:09
Link
It could be that somebody did an "overhaul" and just re-ringed a piston with sloppy ring grooves and also had them gapped too tight.
Henry M
05-29-2007 09:44:44
super 88
As I recall no one answered your question. I have a catalogue that lists 70 gas pistons for 525 in sizes from std thru 125 over. But if I attempt to post the name it will not post.
At that price they must be good ones - groan. Anyway if you have priced around and want that source shot me an email. [email protected]
Mike M
05-29-2007 08:06:01
Forgot to add.
But aren't you glad that you pulled them out for a look ?
G/MAN
05-29-2007 07:30:25
Textbook case of detonation/pre-ignition damage.
ET
05-29-2007 06:41:09
It had broken rings for a lot of hours of running. The pieces came out the top and went out the exaust.
Mike M
05-29-2007 05:55:59
I have seen that before on a G and some 620's. Seems once the bore gets so wore the ring flexing from the thinner rings breaks them ? On the 620 models those pieces start hammering on the head the G and likely your 70 spit them out the exhaust.
buickanddeere
05-28-2007 20:11:01
It must have been suffering detonation from low octane fuel, lean mixtures, low rpm lugging, high air/coolant temps & over advanced timing? Those pistons are only suitable for boat anchors.
buickanddeere
05-28-2007 20:09:56
HAPPY DEERE
05-28-2007 17:22:41
well im saying if i was you i would most definantly take the block in to get everything checked then see after i get teh final word on the block i would commence to buying pistons
mjbrown
05-28-2007 16:47:05
Wow! Didn't that tear up the bores?
super99
05-29-2007 01:40:57
 Re: 70 Overhaul Cheap-NOT in reply to mjbrown, 05-28-2007 16:47:05
I shined a lite in the bores and looked and they didn't look that bad, I'll try to take a picture of them and if it comes out, I'll try to post it. Chris
