730 gears
bigblock
05-28-2007 16:26:45
Where can you buy a transmission bearing kit. I've rebuilt many trannys and a kit is always cheaper.I also need a couple gears.
bigblock
05-29-2007 15:21:15
 Re: 730 gears in reply to bigblock, 05-28-2007 16:26:45
Glen_n_texas,What aftermarket company sells those gears?I need 4th and the lower left gear on the countershaft. 2cyl,that large bearing is the very one I need.The cage came apart and caused my gear problem.
Glen_in_TX
05-29-2007 13:16:10
5th & 6th gears have been available aftermarket for a while and the ones I"ve used or sold have worked fine so far. Some gears could be the same in 70 or 720 also.
2cylinderlp
05-28-2007 19:45:43
third party image
I don't know of a bearing kit for the 730. If you have a John Deere parts book you can check availability of tranny bearings on the JD parts web site. But I'll bet you will find not all the bearings are available through Deere, and one of them is not available anywhere. That one would be the upper shaft left side. It is a large ball bearing. You can just give the John Deere part numbers to a bearing supply and they sould be able to cross reference them. Or you can just give them the numbers right off the bearing after you have completed the disassembly. I did a little of both. I did find an alternative for the one bearing that is not available. There is a bearing that is the proper outside diameter and thickness. It has too large of an inside diameter however. So I had a sleeve made and bonded into the inside diameter of this bearing. That achieved a proper fit on the shaft. It worked out fine, just cost about triple. The other stumbling block I had was the nut on the lower shaft, left side, was really stuck on there. I had to make a tool to get it off. Actually it wasn't until the third tool that I had one that was strong enough to do the job.
