4020 steering valve
Tech 7
05-28-2007 14:50:31
tommorow will be the third time for removing the steering from this tractor. At the moment it is working better than it did but will still lag slightly on a right turn. I have set the valve clearances per TM as acuratly as I feel possible but have as yet been unable to achieve acceptable performance. Any "old" heads have any suggestions with these devils? One day I hope to repair one of these and have it work the FIRST time. Appreciate any input and would be glad to return the favour. Thanks, Bob (BTW Iam the local dealer)
jdemaris
05-29-2007 06:31:27
 Re: 4020 steering valve in reply to Tech 7, 05-28-2007 14:50:31
The reality is - as long as all the valves open and close (and seal), and the return valves open BEFORE the pressure valves, it will work okay. I've done many out in the field with no special tools. Of course, there are many other things that can affect your steering other than just the valves and seats.
dwag
05-28-2007 20:19:41
There is a misprint in the Deere manual, mine anyhow, on valve clearance. Return valves are set at .001, press valves at .003.
matthies
05-28-2007 19:43:03
The dealer I worked for always changed the plate between the top half and the bottom half. Have seen a few cracked through the large hole for the tube.
msb
05-28-2007 18:55:23
Have you: checked the end play of the hinged plates?
Replaced the steering motor 0-rings?
There were a few adjustment jigs that got out with the wrong dowel pin height several years ago if you have one of the older jigs. If you have been a dealer for some time now you should have a service bulletin about it.Don't hold me to it, but .040" sticks in my mind as to the proper height of the dowel pins in the jig.
