Driving me Crazy! Power Trol Plugs
txasylum
05-28-2007 12:11:26
I have been trying to figure out now for a week why I have oil seeping out of my bottom power trol plug on my 1951 B. I have changed the O rings twice, but it still leaks. If I take the plug out and let it sit over night, not a drop of oil. I have tried different plugs, but they all leak. What am I missing here?
Bob
F-I-T
05-29-2007 07:56:37
 Re: Driving me Crazy! Power Trol Plugs in reply to txasylum, 05-28-2007 12:11:26
TS:
Is your Powr-Trol the later style with the snap lever as opposed to the shear washer type? If those nibs that the leaf spring hold inward have any wear on their tips, that could allow the plugs to move rearward a bit. Maybe that is enough to cause the leaking. Dunno. Maybe prop something agianst the plug over night and see if that stops the leak.
BushogPapa
05-28-2007 20:27:51
Try a slightly larger diameter O-ring..??
txasylum
05-29-2007 07:49:07
 Re: Driving me Crazy! Power Trol Plugs in reply to BushogPapa, 05-28-2007 20:27:51
I tried a larger one, but it didn't work. I did put an extra O ring on the plug shaft and that seems to be holding.
txasylum
05-28-2007 15:30:07
I am trying something. I put an O ring around the plug and put it in, so there are 2 O rings in the groove and one on the plug shaft. Crossing my fingers.
johns48jdb
05-28-2007 15:13:29
i was just wondering if a little teflon tape or pipe dope around the threads might help. any chance that there has been a groove cut into the threads under the bottom side of the threaded part that you haven't seen. also take alll the mating parts and place them flat down on a piece of emeryclouth and buff they down flat to see if any burrs are showing up and to true them up a little bit. they may havew gotten bent at some time. polish them a little bit and inspect them close before going on and see if any high spots show up on them.
Mike M
05-28-2007 14:10:56
You say if you take the plug out not a drop of oil ????? ?? It should gush out then ? Are you sure it isn't running down form another place and showing up at the plug ? I'm wondering if you have a crack or a sand hole in the casting ?
txasylum
05-28-2007 14:47:11
 Re: Driving me Crazy! Power Trol Plugs in reply to Mike M, 05-28-2007 14:10:56
I have the oil drained to the point of where it is level with the bottom plug, that way it doesn't leak. I have searched for another location of where it is coming from, but I'm sure it is coming out of the plug hole and only when the plug is in. Strange!
Bob
