4620 Front Tire Size?
Randy Cook
05-28-2007 11:07:02
The 4620 that I purchased has 2 different size tires on the front. I don't remember the sizes, can anyone tell me the proper size that this tractor is supposed to have?
Dean Barker
05-30-2007 18:04:51
 Re: 4620 Front Tire Size? in reply to Randy Cook, 05-28-2007 11:07:02
John Deere 4620 literature lists the following front tires: 9.50-20 8 ply 10.00-16 6 ply 11.00-16 8 ply 14L-16A 6 ply
Stonecreek
05-29-2007 13:24:04
I had a 4520 that was equipped with 10.00 x 16 and a 4620 that was equipped with 11.00 x 16. There's not much difference in either tire. If you are not using an implement that requires a great deal of front end weight then the 10.00 is adequate. Come to think of it, I had a 200 gallon front-mount spray tank that the 10's were carrying and if they were overloaded there was never any sign of it.
Some 4620s may have been equipped with the 14Lx16.1 high floatation tire, but normal usages don't require such a large front.
Glen in TX
05-28-2007 20:54:20
Check the parts catalog?
jd40an
05-28-2007 13:05:47
Mine has 1100x16.
Gerald J.
05-28-2007 12:37:02
They are probably both right. My 4020 manual shows four sizes I think from 7.60-15 to 10.00-16 plus a 20 inch for the hydraulic powered front wheel assist. I have 11.00-16 on my 4020 and they level the tractor. I did have to use wider rims than the originals. It didn't change the level when I put on 12.4-42 in place of the 18.4-34 for spraying.
Without knowing the options, I'd say 11.00-16 or 12.00-16.1 would be appropriate sizes for a 4620.
Gerald J.
Randy Cook
05-28-2007 12:44:58
 Re: 4620 Front Tire Size? in reply to Gerald J., 05-28-2007 12:37:02
Thanks
Gerald J.
05-28-2007 14:34:36
 Re: 4620 Front Tire Size? in reply to Randy Cook, 05-28-2007 12:44:58
I did a google search and it seemed like 11.00-16 came up most often connected to a 4620. I wasn't able to find a Nebraska Tractor Test for that tractor on line and I didn't go look up Lester Larson's book about the tests or my new generation JD books that might have said. 11.00-16 is a nice sized tire that doesn't drop much when crossing plow furrows.
Gerald J.
