60 valve spring replacement without removing head
tmq
05-28-2007 07:49:03
Is it possible to replace a valve spring without removing head. I was firing on one cylinder so I remove valve cover and found an exhaust valve spring broken. The spring keeper had fallen apart as well. Any info would be appreciated.
andy r
05-28-2007 20:27:33
 Re: 60 valve spring replacement without removing h in reply to tmq, 05-28-2007 07:49:03
I changed a valve spring on my 70 gas with a valve spring compressor tool without pressurizing the cylinders. Worked fine. The tool was similar to ones used in small engine work, but larger to accept automotive size valves. I don't know why those valve springs break. I need to change my second one on the 70 this summer.
Mike M
05-28-2007 14:14:19
In addition to the air if you hold the piston at TDC then it should stop the valve short of falling in if something goes wrong.
teddy52food
05-28-2007 21:23:35
 Re: 60 valve spring replacement without removing h in reply to Mike M, 05-28-2007 14:14:19
You can also thread a soft rope through the spark plug hole. Then turn the piston to the front & it will hold the valve shut while you change the spring.
deib
05-28-2007 08:02:31
Make from a old spark plug weld a tire air valve to it so you can blow air in to the cylinder when it is in position for both vales to be closed this will pressurize and hold the valve so you can put a new spring on without losing the valve. deib
