'46 B issues - brakes, cylinders, water pipe, clut
patsdeere
05-27-2007 23:06:55
I have multiple issues that I was hoping somebody could help me with.
1. My right hand brake unit came out with ease. I had a tough time getting the nut off, but finally did. Now I am trying to get the gear off and am having no luck. I have tried pouring tons of penetration oil on it, adding a little bit of heat (but don't have the right torch), a gear puller and a big pry bar. Nothing seems to break it loose. Any ideas?
2. I pulled the head off and I have 1 cylinder that is 1/3 full of rust (boohoo :( ). Will this mean that I need to have both cylinders rebored and put in slightly larger pistons? Or if they are bored back to the original size I just might need new rings for the cylinder.
3. My upper water pipe has seen better days. Is there a way to pull the pipe out of the cast base and replace it? If it can't be pulled out would cutting it off at good metal and welding on a new section work?
4. I tried to pull my clutch out of the drum and it won't come off the splines. I have tried the gear puller and no movement. Any ideas on how I can pull it off?
Thanks for any help (as I am too young to go bald over this dumb machine).
Mike M
05-28-2007 14:25:01
 Re: '46 B issues - brakes, cylinders, water pipe, in reply to patsdeere, 05-27-2007 23:06:55
Alot to cover in one posting.
Brakes; Try to back off the adjuster if it will move,most are stuck. Then put the big nut back on to protect the threads lift the whole assy. up start about 1 foot off the ground and drop it on a hardwood block on a concrete floor nut first. Go higher if needed,this almost always gets them loose.
Block; You can sleeve back to std. and use your old pistons if still good with new rings or find some oversize pistons,or find another block. There are still even some NOS ones around for that years.
Upperpipe; K & K antique tractors sells those replacement upper pipes,they may even put them in for you ? or we can go into more detail when your ready. It'll be awhile as you got alot of other stuff to do first. I do them after the block and rad. are back in so I can align them back up.
Clutch driver; Get a good puller and get it tight and give it a hard whack !!!
wilamayb
05-28-2007 13:22:13
You need a technical manual in the worst way. You should give your local dealer a call ASAP to have them order you one. If you dont want to spend the big bucks to get a Deere manual you can use an I&T which will help some.
In the meantime I'll help you with the problems that you have since you'll be needing to go to the dealer to order brake parts anyway.
To get those brakes apart you need to put the assy. back on the tractor. Go ahead and loosen the nuts so that it is not touching the lockwasher. Get yourself a block of wood and a big hammer and give it a good wack to get those shafts out of the assy. I think on letter series you can lose the shafts in the trans if you take the nut off at this point, so dont take the nut all the way off until you have it pulled out of the tractor.
Your almost all the way to having the block off anyway, so go for it. Having that block bored and new pistons will be a little pricey, but It'll run like a dream. You'll have to decide if its worth it.
There has been all kinds of top water pipes fixed. You can weld in a new pipe, fix it with JB Weld, Cut out the bad section and replace with a rubber hose. I'm sure there is one in a salvage yard, but that may be more than you are willing to pay. I'd call and ask beore you spend too much on your pipe.
As for the clutch driver... They can be a little tough, but the good news is if it's tight then the splines are good on your crank. I wouldnt apply heat if at all possible. The best thing for a tight fit is a good solid smack with a dead blow hammer. My advise would be to put your puller back on and get her good and tight and then give that center a good wack.
To be on the safe side for your crank cut yourself a thick piece of metal to go on the end of your crank for the center of your puller to pry on. This will save the threads in your crankshaft. At this point you can give it as big of a wack as your puller will withstand. What will get this thing loose is lots of pressure from your puller and then a GOOD square solid blow from a heavy hammer.
Dont forget.... Get yourself a manual before you break something that's expensive!!!
larry baker
05-28-2007 08:25:58
sounds like a real bear.sometimes you have to think how much it will cost to fix it and you may have bought a tractor that would be cheaper to use as parts and get another ..the problems you have can all be repaired but work at them one at a time and dont worry about repair until you get them all down and looked at and then calculate the cost of what your doing.The parts you need and machine work all of which you mentioned are available.either way if needed contact us for both .have a good weekend
