JD 41 A PTO not turning
Shipwreck
05-27-2007 14:50:22
My 41 A when I got it had a rock shift problem. Me and my Dad monkeyed with it for a long time but finally got it working. Things worked fine for a month or so and now a new problem has come up.
The PTO shaft just stopped turning. It worked fine but now nothing. You can turn it by hand but when you engage the PTO shift lever and engage the clutch nothing.
I did notice a noise coming from the PTO shaft when it was working like metal rubbing when it turned. When it stopped working I drained the oil out of the power trol and did notice a piece of metal. Sort of like a pin or nail looking thing.
Is it possible to have not gotten the shaft aligned right when we put the pump back in?? The bolts tightened up just fine so I did not think so.
Any ideas where I should start looking?? Will taking the floor board up allow me to look inside??
Any help you can provide would be great.
Thanks
DSK
05-27-2007 17:20:48
 Re: JD 41 A PTO not turning in reply to Shipwreck, 05-27-2007 14:50:22
Start by draining the transmission oil. Remove the seat/platform assembly and all the bolts that hold the entire rear housing to the axle housing. Support the housing with a chain from a loader bucket or better a chain hoist. When you get the housing off it should be obvious what the problem is. The PTO on these tractors is a simple design, but like the earlier post said, a manual will help considerably.
Mike M
05-27-2007 17:13:31
If you pull off the tranny top cover and drain the oil you may be able to see if the bevel gears are turning. You may just have a bad coupling ( not sure if that model uses them ) or a bad shaft then you will have to pull the back off again.
cole in mo.
05-27-2007 17:00:46
You've got a lot more to do than just take the floor pan off to see what the problem is, first thing to do is get a manual.
