3020 electrical problems
chris comer
05-27-2007 11:32:44
1968 3020 gas one battery 12 volt positive ground. My tractor has the gen light on all the time and after running, it is hard to start or wont turn over at all.Put jumpoer cables on and starts right up. Had battery checked at auto zone tested good. Put on brand new 140 dollar gen. Polarized it, I think. Still light on.Still same problem. not sure what to do. Probably wasted my money on new genrator.Working on electrical new for me. I should have checked old gen. first. I have no voltmeter and dont know how to test with one. Thank you everyone.
Bob
05-27-2007 12:07:44
 Re: 3020 electrical problems in reply to chris comer, 05-27-2007 11:32:44
Check the voltage at the battery, after running a bit. Should be 14 Volts or a little more. If not, try MOMENTARILY grounding the "F" (Field) terminal at the generator. If the voltage begins to come up, this points to a voltage regulator problem, or the wires between the voltage regulator and the generator.
(DO NOT leave the temporary jumper in place for very long, "full-fielding" the generator, or it may begin to overheat.
Chris comer
05-27-2007 12:28:28
 Re: 3020 electrical problems in reply to Bob, 05-27-2007 12:07:44
Thank You I have a few questions. Is the f terminal on the regulator? Were do I ground on the gen? On one of the posts or just touch the metal case of gen?
Bob
05-27-2007 12:44:10
 Re: 3020 electrical problems in reply to Chris comer, 05-27-2007 12:28:28
BOTH the voltage regulator AND the generator will have a post marked "F" or "FLD", all the same thing, meaning "FIELD" I suggested grounding the post at the generator, in case there is a problem with the wire from the generator to the VR.
ANY good, clean chassis ground will work, including the metal case of the generator.
Chris Comer
05-27-2007 13:09:03
 Re: 3020 electrical problems in reply to Bob, 05-27-2007 12:44:10
Got it. Will be a couple of days before I can work on it. Thank you very much.
