FIT - Electrolysis No's ??
Gary U in CA
05-27-2007 08:15:15
Hello Frank
I have a quick question regarding Electrolysis:
Are there any materials that should not undergo electrolysis - i.e. what would I not want to expose in a pony motor?
All is well out here - what's the latest on Pasadena?
Gary
F-I-T
05-27-2007 13:06:07
 Re: FIT - Electrolysis No's ?? in reply to Gary U in CA, 05-27-2007 08:15:15
Hi Gary:
I avoid any white metals,(aluminum, magnesium, pot), also, I avoid copper, not because it seems to get attacked, but it can throw extra rogue ions in the bath, so why polluote it any faster than it might get anyway. Bronze has not been a problem for me, so it's ok.
So, for a pony, don't dip the distributor body, rods, pistons, or carburetor body. The rest ought to be fine. If you can get a few stubby electrodes down in the water jasket where the sleeve o-rings are located, it will help get the rust and deposits out of there in case you have sleeves that are "stuck". Rinse the block off with a lot of hot water to clean it and to get the cast iron temp up so evaporation dries the surface quickly to minimize surface rusting. You'll want to blow out all of the oil journals, probably after a through brushing.
Pasadena is all right, looks like I'm there through the summer at a minimum. They'd like me to take a accept a permanent position, but I don't want to relocate. I'll try to work out a stay-out-there weekend down stream and maybe we'll get together for another visit.
Frank
Gary U in CA
05-27-2007 15:10:05
 Re: FIT - Electrolysis No's ?? in reply to F-I-T, 05-27-2007 13:06:07
Superb!
Any concerns within the transmission? It just sounds like this is really going to be easy.
Glad to hear that you will be here for a bit. Keep an eye on the club calendar for any shows or parades you'd like to do. You have your choice of tactors to drive.
Thanks!
Gary
F-I-T
05-27-2007 16:20:18
 Re: FIT - Electrolysis No's ?? in reply to Gary U in CA, 05-27-2007 15:10:05
I cooked the transmissions, but generally the gears are pretty clean. Since I always replace the two bearings and the bushings, I e-tank the housings, and it does a great job on 'em.
Gary U in CA
05-28-2007 06:00:48
 Re: FIT - Electrolysis No's ?? in reply to F-I-T, 05-27-2007 16:20:18
Your the best!
Hope we can see you real soon,
Gary
