2010D Fuel Problem
Bob in NH
05-27-2007 04:11:39
I have a 64 2010D which I have owned for 1-1/2 yrs. Has been running OK, except an occasional "skip" since I bought it. On the way back from spreading fertilizer the other day, tractor started missing badly and died on the highway, would not start. We checked and weren't getting fuel out of the filter bleed valve. Pulled filter and no fuel coming from tank. We have eliminated the blockage at the tank, replaced the fuel line to the filter (still had original line on it), cleaned filter bowl and screen, replaced element, and are now getting good flow to the pump. However, when we have tried to bleed the lines at the injectors we get little or no pressure and flow.
Reading the archives, it appears that the next step is to check the return from pump to tank for blockage. Can anyone add any advice or comments here?
Thanks much!
Lindsay Smith
06-07-2007 04:00:43
 Re: 2010D Fuel Problem in reply to Bob in NH, 05-27-2007 04:11:39
I have seen this problem on many JD2010"s over the years. It has been caused by a broken sealing ring in the pump. It can be checked by bleeding fuel from the inspection plate while the motor is running. The motor will speed up.Often if you leave the tractor after it has died, go and have a cup of tea or two and go back it may start before stalling again. I have seen at least 20 tractors that have done this. Common with Roosa Master pumps of this era.
Bob in NH
06-07-2007 15:21:30
 Re: 2010D Fuel Problem in reply to Lindsay Smith, 06-07-2007 04:00:43
Thanks much for all the ideas. I finally got a friend involved who works on diesel trucks and he said TOW IT. I had been trying to get my haying partner to do this for over a week (tractor was at his welding shop). We towed it less than 10 feet and it was running. No problems since!
Joe Stewart
05-27-2007 07:59:04
Sounds like you"ve already fixed the blockage problem and now the system needs a good bleed. Temporarily, put an electric fuel pump on it to force fuel into the pump in order to assist in bleeding. In this way, you won"t have to keep cranking the starter (and burn it up, as I"ve done in the past on my 2010D). Start up the engine to get out all the air, then, take the electric pump off and run it just like before all this occurred. Another tip if you don"t have an electric pump: remove the timing plate (held on with two screws) off of the side of the injection pump and open the stopcock on your fuel supply lines. This will allow the injection pump itself to fill up with fuel (its probably filled with air now). When fuel comes pouring out of the timing port, replace timing plate and continue cranking motor until fuel shows up at the injectors. Tighten injector lines and start engine. This saves on a ton of cranking and will spare your starter. I"m sure you"ve alread done this, but if you think the return line is blocked, blow some air through it to gauge its patency. Good luck
Bob in NH
05-27-2007 08:36:52
 Re: 2010D Fuel Problem in reply to Joe Stewart, 05-27-2007 07:59:04
Joe, One question. Where would you put the electric fuel pump? Between tank and filter or between filter and injector pump?
jdemaris
05-27-2007 13:12:28
 Re: 2010D Fuel Problem in reply to Bob in NH, 05-27-2007 08:36:52
You don't want to install anything between the filter the injection pump. Otherwise debris, such as something from a failed fuel pump, could trash your injection pump.
In regard to installing an electric pump. Generally speaking, it should not make a bit of difference - assuming your gravity feed is working properly and also assuming your injection pump is okay. The Roosamaster DB pump is an easy bleeder - regardless if it's getting gravity fed fuel as less then 1 PSI, or pressure fed from a 4 PSI fuel-pump. The injection pump has it's own internal fuel transfer pump already - unless yours is not working. Your pump is probably a DBGVC431-1J or something close? What does happen in the older injection pumps is . . . the internal pump vanes get worn out. When this happens, it affects high speed running along with starting. The older style pump vanes are solid and non-metallic and do NOT self-adjust. The newer stye pump vanes are spring-loaded steel and DO self-adjust. If you pull the timing window off the pump and find a bunch of debris in there that looks like mouse turds - then the injection pump has a failed plastic weight retainer and needs repair.
Bob in NH
05-27-2007 08:31:51
Thanks Joe. Tractor is still at a neighbor's about 2 miles away so I haven't gotten there yet today to check the return. His JD 302 Industrial and Ford 5000 both have pumps in-line to prime the system. I ran this 2010 out of fuel once last fall and know the toll on the starter. Unfortunately mine has a Prestolite on it's last legs anyway (Internal solenoid is pretty much toast), A local starter shop is building me a Delco to replace it and I should have it next Thursday!
I wish that JD put some of this wisdom into the SM-2035 Service Manual!
