Need help from MSB, JDEMARIS, G-MAN, others
Tom43
05-27-2007 01:25:32
I have a completely restored 1971 4020 syncro-range that is very hard to shift even with a rebuilt clutch and rebuilt transmission. The shift lever must be jerked into gear. Please advise me how to correct this.
jdemaris
05-27-2007 13:20:08
 Re: Need help from MSB, JDEMARIS, G-MAN, others in reply to Tom43, 05-27-2007 01:25:32
My first guess is - that somebody ruined your engine clutch disk when putting the two tractor halves back together. That's pretty easy to do if not experienced. 4020 has two clutch disks that must line up with two different sets of splined shafts - and I've seen people get frustrated, force a tractor back together, and warp the clutch disks. If that has happened - it will never shift good until it gets pulled back apart and fixed. I've done many, out in the field by myself with no high-tech equipment. But, that's when I was young and saw it as a challenge - instead of a royal pain in the a**. When I worked for Deere, I'd go out, pull one apart in the barnyard or field, put new clutches in, lock the PTO clutch fingers with splinters of wood, and then use two come-alongs to pull the tractor back together. But, I'd do so carefully, and never force it. And, keep cranking the engine over - AND - turning the PTO shaft back and forth until I felt the splines engage. If you dont do that, you will cause some damage.
msb
05-27-2007 18:31:30
 Good point ,John in reply to jdemaris, 05-27-2007 13:20:08
It could easily be a warped disk that was why I asked if the tractor could easily be shifted with the engine not running.----I had to replace an engine block when someone pulled a 420 "together" with a comealong and long bolts several years ago.Actually broke the ears off the block.
msb
05-27-2007 09:57:20
Kind of hard to say from where I sit without driving the tractor.Could be dozens of things causing it.How does it shift without the engine running? Does it grind gears or is it just very hard to shift? You could have some balky detents.You might try using some ball and socket detents that the 2010s used. How did it shift before the transmission job? You might also check the end play on the shifters.Jiggle the gearshift to make sure the detents are exactly centered and then see if the shift lever lines up with the exact center of each gear slot. If not, adjust the linkage so it does.
Bob
05-27-2007 11:03:48
 MSB... in reply to msb, 05-27-2007 09:57:20
In his first post, I replied "If you had major "topshaft" repairs to the tranny, it MAY get better with some hours on it. Those shift collars are pretty tight 'til things get polished up a bit from use."
Do you think I am off-base with that reply?
I have done quite a few of these over the years, and, often, the new sliding shift collar parts for the topshaft are REALLY tight when first assembled. Have you run into this?
Of course, a clutch that's "dragging" can certainly cause the problem, as well.
msb
05-27-2007 18:23:45
 Re: MSB... in reply to Bob, 05-27-2007 11:03:48
Not at all, Bob. I didn't connect the two posts.
Tx Jim
05-27-2007 03:08:50
Is your clutch releasing completely? Were the drive clutch and pto clutch set properly with the correct tool? Did you apply a small amount of grease in pilot bushing? Did a qualified tech with the correct special tools rebuild the transmission? Tx Jim
