3020 won't idle right
JFoshee
05-26-2007 21:40:45
I usually visit the dozer forum, but I had a question about my JD 3020 I needed answered. After you jump it off, or roll it down a hill, because the batteries won't stay up, it won't idle correctly. You don't have to be doing anything to make this happen just sitting there idle. After a period of only a couple of minutes it begins to increase the RPM. It can get pretty high. If you give it some fuel with the foot throttle, or hand throttle, and return to idle position it will start all over again. I realize this is a fuel pump problem. I just would like to know what in the fuel pump is causing this? Also is there mabey something I could do to fix it?
Tx jim
05-27-2007 03:15:10
 Re: 3020 won't idle right in reply to JFoshee, 05-26-2007 21:40:45
Govenor in injection pump is the problem. I'd advise repairing it before a rod comes through the block. Your batterry drain is most likely in starter if it's still a 24v system. Tx Jim
