Hard Shifting 4020
Tom43
05-26-2007 16:10:35
Dear 4020 experts,
I just had my 1971 syncro-range 4020 totally restored. The transmission lever is very hard to shift and the lever must be jerked into gear. The transmission was rebuilt. Please give me some suggestions as to what I might do to improve this condition.
DSK
05-26-2007 19:49:11
 Re: Hard Shifting 4020 in reply to Tom43, 05-26-2007 16:10:35
Most of the syncro-range shifting difficulties can be traced to clutch problems or a misadjusted shifting linkage. Was the clutch replaced and if so is it properly adjusted with proper free play. A dragging clutch will definately make them shift hard. Your quadrant may also need rebuilding (replace bushings). Continued jerking on the lever will result in broken linkage rods or as I have seen, a broke off shift lever.
Bob
05-26-2007 17:02:25
If you had major "topshaft" repairs to the tranny, it MAY get better with some hours on it. Those shift collars are pretty tight 'til things get polished up a bit from use.
