G Carb Idle Stop Spring
pa_popper
05-26-2007 14:15:29
On a 1951 G with a DLTX 51 carb, how do you replace the Idle Stop Spring (the little spring that the idle screw bumps up against on top of the carb)? Is it held in by a screw from the inside of the carb? Mine is bent slightly backwards and I'd like to rotate it 180 degrees if possible (or replace it if necessary).
Thanks...
Earl-IL
05-26-2007 15:45:29
 Re: G Carb Idle Stop Spring in reply to pa_popper, 05-26-2007 14:15:29
You can get it new. It drives in. Earl
