FIT (or anyone) - More help on my deck
James-Deere
05-26-2007 13:07:58
So I got my 60" deck on my 855 connected and operable. So now the up&down question.
There is the little handle in front of the seat that I can get to move it up and down, but that seems to be hard to do, almost to the point of breaking the handle. Am I missing something here? Is that the only way to get the deck up&down?
This deck is loud also, as someone else mentioned. It may change once I run it over some grass.
I might have to remove the deck to get the tractor back on the trailer. Which sux. I don't have much concrete at the property to hook it back up on.
TIA
F-I-T
05-26-2007 14:11:33
 Re: FIT (or anyone) - More help on my deck in reply to James-Deere, 05-26-2007 13:07:58
JD:
I'm short on time right now until later, as I am trying to get my house and workshop LAN up and running, but for now:
The crank on the center panel is a plastic hub that turns a pretty large (maybe 3/4") thread hex head bolt that adjusts how far the bell crank that holds the two rear hanging straps can travel down by gravity. If you remove the center plate, you can lube that bolt and free it up. IF YOU ARE TRYING TO MOVE THE CRANK WITH THE DECK HANGING ON IT, YOU WILL BREAK THE CRANK. You only make adjustments to that crank setting with the deck full up. Your lifting straps should , and the deck should come up come up when you raise the 3 pt.
Loud decks are a whole 'nuther thing. Grease it up and go from there. It might need bearings, or it mught be dry.
C U Later when I'm back on the air.
Frank
