G with 7-1 Power Block. What does that mean?
Ben.So.Tex
05-25-2007 19:02:10
My G has a power Block with the # 7-1, What does this stand for? Totally confused. Ben..... ..... .
Rob Hartman
05-26-2007 19:03:57
 Re: G with 7-1 Power Block. What does that mean? in reply to Ben.So.Tex, 05-25-2007 19:02:10
I have a 7-2 Power Block. Does this only fit a 70? I thought it would fit a late G also. I thought there were only 2 #7 Power Blocks, a 1 and 2. I've never seen a 3. Only in A's and B's on account of the engine changes.
Thanks to F-I-T Drew
05-26-2007 11:44:19
Now if someone ask me I will have a fairly good answer for them if I don't mess it up.
Thanks BEN
F-I-T
05-25-2007 19:38:10
Ben:
It means that it is a Tractor Supply Block, 7" bore, and the #1 version. I can't remember which way they go, but I think the #1 was for early G's, the #2 for later G's, and the #3 for late, late G's and 70's. Somebody correct me on the order, but the 7 is for 7" bore, as the #6 version was a 6" bore for the A's and 60, and the #5 was the 5" bore for the B family through the 50.
Frank
Drew
05-25-2007 19:41:38
 Re: G with 7-1 Power Block. What does that mean? in reply to F-I-T, 05-25-2007 19:38:10
The 7-1 fits all G"s, and the 7-2 fits the 70 gas. The 7-1 is 12.5" long and the 7-2 is about 10.125"(I think...) They are both 6.500" bore and not 7.000"
Drew
05-27-2007 12:42:23
 Re: G with 7-1 Power Block. What does that mean? in reply to Drew, 05-25-2007 19:41:38
Just realized I typoed, the 7-1 is 11.5" long, the same as a styled block.
F-I-T
05-25-2007 19:48:34
And that's why I said I wasn't sure, but I knew they went 7=G family, 6=A family, 5=B family. Thank you Drew.
