4620 Questions
Randy Cook
05-25-2007 18:50:02
I just purchased a 4620 and have a few questions. I'm using it on our 120 acres to make food plots for deer, bush hog what can't be cut for hay (our neighbor cuts the hay), and clean up where we've cleared fence rows etc...
Questions:
1. Can the tractor pull a 7 or 8 foot 540 rpm bush hog at low engine rpms since it's a 1000 rpm pto?
2. With single rear tires, can this tractor pull a 14 foot wide cultivator?
3. Will a cultivator break undisturbed ground?
I have more questions, but I'll stop there for now.
Thanks.
dds-inc
05-25-2007 20:41:36
 Re: 4620 Questions in reply to Randy Cook, 05-25-2007 18:50:02
8 foot bush hog? A 4620 should be able to handle an 18 foot BATWING mower with all that horsepower!
What a waste of fuel!
Randy Cook
05-25-2007 21:05:34
 Re: 4620 Questions in reply to dds-inc, 05-25-2007 20:41:36
Yea, it's a waste of fuel, but it's a "chore" tractor. We have a 30 hp tractor that won't hardly pull a tree limb much less a tree... it has a very hard time pulling a 6 foot bush hog. A small single shank ripper will stop it dead in it's tracks.
I don't have a bush hog for the 4620 yet, but a batwing would be slight overkill (kind of like the tractor is) but hey... it's a $2500 tractor that runs great, 70% tires, and it won't say no to anything I want to pull with it.
I think a 10 foot cutter would be about right for the work we need to do, and I could probably find a used one with 1000 rpm gearbox pretty cheap.
dds-inc
05-26-2007 19:17:18
 Re: 4620 Questions in reply to Randy Cook, 05-25-2007 21:05:34
I didn't mean to get on your case. I realize big batwings are, in fact, expensive.
F-I-T
05-26-2007 03:49:16
I know what you're saying Randy. You can get those big-but-too-old-for-front-line-tillage-operations-anymore tractors so cheap, the fuel cost is pretty much secondary, given the huge amount of work you can get out of them. I found a 4620 and a 4520 for two of my friends who had bought some pretty trashy acreage, and they just love'm because there is nothing that they can't pull out, drive over, or chop up.
I'd think that if you had a heavy two or maybe three shank ripper, you might tear it up or bend it, but it would stir up and debride the roots from the fencerows. The 1000 rpm bush hogs I've seen tend to be pretty wide, but they don't have all that many around here.
Frank
Randy Cook
05-26-2007 07:08:22
 Re: 4620 Questions in reply to F-I-T, 05-26-2007 03:49:16
Thanks for the reply. I've found several 1000 rpm bush hogs in the $1500-$2000 range around 12 foot wide... that ought to do it. We've cleaned most of the fence rows already with a dozer and trackhoe, it would be a shame (and costly) to let them get out of hand again. We also have the underbrush and small trees cleared from 4 acres next to the house, the small tractor works itself (and me) to death trying to keep it clean. The 4620 should have no problem.
Another question... What size dirt pans will it pull with singled or dualled up rear tires?
Thanks again.
Glen in TX
05-26-2007 08:47:37
 Re: 4620 Questions in reply to Randy Cook, 05-26-2007 07:08:22
Dirt pans? I assume you mean box blades? 12 ft. is a pretty common size and maybe bigger than you want if you have any narrow gates to get thru. You can load it pretty good with 12 ft so 10 might be all you want. If just doing road maintainance you won't need duals. Same on shredder a 12, 14, 16 would be plenty and a 10 or 12 ft. easier to get around with and anything wider that doesn't flex won't work well in ditch banks or along terraces if you have much of that. Seen some put 18-20 ft. bat wings on a tractor like that and the smoke just rolls out on a older one and not long before you see it parked and thrashed. Keep something smaller on it for your use and it will last you a long time probably. Main things to watch on used shredders would be are the gear boxes good and not noisy and are parts and blades readily available local.
Randy Cook
05-26-2007 17:21:53
 Re: 4620 Questions in reply to Glen in TX, 05-26-2007 08:47:37
Yes, I did mean dirt pan... scraper. 6 yard dirt pans are common around here. Thanks for the info, I've located a couple 12' bush hogs, 3 point hitch style, that should work good?
Glen in TX
05-26-2007 20:54:43
 Re: 4620 Questions in reply to Randy Cook, 05-26-2007 17:21:53
Yeah the 3 point shredders will work fine too. Might be better depending on the lay of your land. Larger 3 point JD or Rhino ones were popular here. I remember seeing lots of problems with some of the earlier JD 12 ft. or 14 ft. 3 point ones though with gear boxes and hitches breaking out too but they were running most of those over rough CRP ground and not just crop stalks.
buickanddeere
05-25-2007 20:16:14
The cultivator should if it's equiped with points rather than shovels.
flying belgian
05-25-2007 19:54:35
gosh I think the 4620 is about 130 horsepower that should handle the bush hog with the tractor throttled down to 540 pto. yes you can get a 1000 to 540 adapter at TSC. aMake sure you don't overspeed the bush hog.
Randy Cook
05-25-2007 19:54:19
Thanks for the input. For safety's sake, I think I'll get a larger pull type bush hog with a 1000 rpm gearbox or purchase a new smaller cutter and have a 1000 rpm gearbox installed, King Kutter's are made locally.
I can get a cultivator really cheap ($300) and was wondering if multiple passes would break the ground sufficiently to make a couple 2 acre deer plots. It might be worth a try since I don't have a disc. I may need to find a ripper (I think it's called something else in farming) to break the ground.
PreciseFarms
05-25-2007 19:25:48
The 4620 will handle the cultivator, but it will not do a very good job on unbroken ground. Its made more for disked ground as a finishing tool. Try disking a few times before using it, unless there is little or no vegetation and plenty of moisture in the ground (not wet though). I believe someone makes adapters to go from 1000rpm tractor shaft to 540rpm implement or you could just replace the end of the bush hog shaft. My dad and his cousins did something similar with a grain dryer but it was done by replacing belts and pulleys. However, the theory is the same. They use 1000rpm shaft idled down to do the same job as 540rpm at rated speed.
