1949 B clutch adjustment
Roy Lemmond
05-25-2007 18:23:50
I am having trouble adjusting the clutch on my 1949 JD B tractor. The clutch dogs may be worn as I bought a used pulley and adjusting bolts. I have a question for you techs. When I tighten the adusting bolts, does that make my clutch tighter or looser?
Roy Lemmond
05-27-2007 19:28:41
 Re: 1949 B clutch adjustment in reply to Roy Lemmond, 05-25-2007 18:23:50
Thanks Frank for your input. I have an operators manual and a repair manual. I still need the parts manual. When I adjust the clutch and crank the engine, I can't operate the clutch without a grinding noise. When I force the clutch in gear, I start moving and it is hard to release the clutch. I will e-mail you in a little more detail. Thanks.
Roy Lemmond
05-27-2007 19:28:33
F-I-T
05-25-2007 18:37:51
third party image
Roy:
Tighter. The theory is such that when you move the clutch lever forward, you pivot the bell crank that actuates the bronze yoke, which moves the operating sleeve, which push the toggles which move the dogs which pull back on the heads of the t-bolts, compressing the linings against the clutch driver. If you did not have the nuts on the bolts, they would just pull inward, and not pull on the outer clutch adjusting disk, and the clutch pack would not pinch the driver, and so would not have any effect. So the opposite is that is you tighten them too much you can't engage the clutch, thighter makes the clutch resist slipping.
Frank
Roy Lemmond
05-26-2007 18:04:57
 Re: 1949 B clutch adjustment in reply to F-I-T, 05-25-2007 18:37:51
Thanks for the info and the diagram. I have tightened the adjusting nuts and my clutch does not release. I have tried the clutch with the adjusting nuts looser, still no clutch. I have some toggles out of my old clutch assembly--I will try installing them.
Mike M
05-27-2007 05:16:34
 Re: 1949 B clutch adjustment in reply to Roy Lemmond, 05-26-2007 18:04:57
You need to get a picture of a tractor your year ( one above is too old ) and make sure you have all the parts in the correct order. Make sure the cotter pins that hold the bolts in aren't binding on the clutch plate or driver. It is very close fit in there and they have to be bent the right way to clear.
Leave the nuts loose so you can work the lever back and forth and watch to see it all works freely and the pulley turns freely. Tighten them up a little at a time until you can see/feel it tighten up you should start to get some snapping action as you tighten up the nuts. I like to use a beam type torque wrench to get the nuts even pressure,usually only up to about 10 or 15 ft. lbs. will give the required amount of pull at the lever to engage and disengage. Book says like up to 80 pounds pull at the lever which is very tight and most ( me included ) don't run that tight unless they are doing heavy work.
F-I-T
05-27-2007 07:06:14
 Re: 1949 B clutch adjustment in reply to Mike M, 05-27-2007 05:16:34
third party image
Ok, so here's the late styled pulley parts breakdown photo. I already had the older one on the server so I posted it as a "reference only" picture in the interest of expediency. I believed that if one could understand how the clutch worked from this pre-201,000 illustration, you'd pretty much know how to arrange the parts in your particular model if not virtually any two cylinder clutch pack. That said, Roy, nothing beats having your own parts book and an I&T manal at a minimum. It covers the how-to on clutch assembly in step by step fashion.
FWIW, it does take considerable time to search for, copy, edit, trim, post, and link photos. If others could help in that regard, fewer people would have to suffer with my lack of attention to accuracy. My server is getting pretty full of ref pics like this, and one of these days the older ones are going to have to get purged. It gets kind of lonely maintaining a server to post pics on so everyone else can tell you which ones you could have done a better job with, so jump in and I'll gladly sit back and give my serve a rest.
Mike M
05-27-2007 12:38:18
 Re: 1949 B clutch adjustment in reply to F-I-T, 05-27-2007 07:06:14
Frank: I hope you don't think I directed any comments directly to you as I did not. I suggested this fellow obtain a correct diagram for his model. He may allready have one or a parts book ? I don't know he didn't say ? I have seen more than a few of those put in wrong.
I don't see how you find the time to do all you do here plus you are still fixing up your own tractors. There are alot of newbies to these old tractors these days which is really good ,but I sure do wish they knew how much info they are missing out on by not having the John Deere parts ,service and operators manuals and READING through them first and then asking questions. Disclaimer---The proceeding was not directed at any one person/persons.
F-I-T
05-27-2007 04:50:05
Roy:
>>>I have tightened the adjusting nuts and my clutch does not release. I have tried the clutch with the adjusting nuts looser, still no clutch.>>>
What do you mean by clutch will not release? Do you mean that it won't puyll out of engagement? THen you say "no clutch". Do you mean that loose or tight, the clutch does not engage? Shoot me an e-mail af [email protected] if you like. I think I need more detail.
Frank
