630 temp gauge?
EH in SC
05-25-2007 13:53:20
My 630 arrived yesterday and I am really pleased! Needs very little in the way of TLC to use right away and thanks to al who answered my first posts! Operator's manual is ordered from Deere, but want to know how to trouble shoot the temp gauge, never comes off 140 degrees. Water and antifreeze are OK and were changed before the previous owner shipped tractor, as were all fluids! Any help would be much appreciated
F-I-T
05-25-2007 14:47:26
 Re: 630 temp gauge? in reply to EH in SC, 05-25-2007 13:53:20
EH:
Sorry to say that there isn't much in the way of trouble shooting that you can perform. The temperature gauge uses a bulb and tube filled with ether, and that expands and pushes against the spiral tube and that pulls the chain that moves the needle.
So, if you are cerain that the engine is truly at a temperature of above the minimum gauge reading, then your gauge probably has a leak na dhas lost its ether. Some folks repair them, or you can buy a suitable replacment for about the same money.
Frank
EH in SC
05-25-2007 18:29:30
 Re: 630 temp gauge? in reply to F-I-T, 05-25-2007 14:47:26
F-I-T:
Thanks very much for the reply! I was in hopes that there was a way to test the sending unit and gauge seperately to determine the culprit. Since I am so new to this, I am assuming that the tractor should be warmer than 140 degrees after about an hour of run time. I also know what happens to those who assume! Thanks again!
PJH
05-26-2007 09:53:20
 Re: 630 temp gauge? in reply to EH in SC, 05-25-2007 18:29:30
My 630 heat guage would stay on 140 degrees all day until I installed a thermostat. The previous owner ran it without a thermostat - They run better with a thermostat to warm it up to op. temp.
EH in SC
05-27-2007 19:51:22
 Re: 630 temp gauge? in reply to PJH, 05-26-2007 09:53:20
Thanks PJH! Will the correct thermostat info be in my operator's manual when it comes? If not, could you or someone please send me in the right direction with specs for it? Any tricks I should know or is it just like changing one in auto? Thanks again for the help!
