JD 14 t baler questions?
t.r.y.
05-24-2007 22:35:18
Hello we finally got our 14t tieing every bale with out missing, we just can't seem to figure out how to change the weight/size of the bale. with the adjust screws only in 2 turn of both sides bales are still to long and weigh around 80lbs apiece. Excellent dry! grass hay. Not sure what else to do. all around nice baler if we can figure this out. thanks in advance.
johns48jdb
05-27-2007 07:42:31
 Re: JD 14 t baler questions? in reply to t.r.y., 05-24-2007 22:35:18
guys a word of caution if you don't mind. we've had 33 acres of hay burn up right around me in n al because the hay is so dry that just the heat from a bad bearing is setting the fields and baled hay on fire. i'd see to it that each tractor and truck has a fire exrtinguisher on it just to be on the safe side. even just the old type baking soda extinghushers would work good. hay here in na l is already bring 10 -12 dollars for square baled horse hay and people are driving 100's of miles to get it, if they can find somebody who will part with it at all.
Bob
05-24-2007 22:40:30
The measuring wheel "star wheel" that runs on top of the bale is made of slotted segments.
For longer bales, move the segments outward, to increase the diameter of the wheel. For shorter bales, move the segments inward, to decrease the diameter of the measuring wheel.
WV2cyl
05-25-2007 03:22:52
 Re: JD 14 t baler questions? in reply to Bob, 05-24-2007 22:40:30
Bob, I have not seen a pic of his baler or know of its age but the later 14T balers had an adjustment on the trip angle on the knotters, just loosen a little set screw and adjust the size of the bales. Could be that the hay is not dry enough or the bale chamber is still rusty that it is making heavier bales. I hope to be able to start baleing here next week on my 14T that I bought new in "64 and have used every year since. It is so dry here in Eastern WV and the hay so short that I will most likely have to take a bale of hay from the barn just to prime the baler as we had to take water to prime the old pitcher pumps.
