F I T what did you do on....
Nylon
05-24-2007 21:53:27
What did you do with the rear axles on that 70 as far as paint? I have been looking at front wheels to see which way they were painted. I see that your grease caps are yellow and not green as some have I seen. But I cant tell what the rear axle stubs look like. After getting my wedge blocks to let got, I anti seized everything...including the axle stubs. I will clean them off but never knew what to do with them. If they get painted wont the wedge blocks pressure stick to the paint? or maybe they are not painted. I am also shooting an e mail on that electrolosis info.
F-I-T
05-25-2007 04:22:55
 Re: F I T what did you do on.... in reply to Nylon, 05-24-2007 21:53:27
First off, no matter what anyone tells you, the ENITRE front wheel was yellow because those were painted as entire unit away from the tractor then installed after the green was done. The hub, wheel, and lugs bolts were painted and the tube and tire mounted on. Then the wheel assembly was installed on the tractor, and the only fasteners on the outside to see a wrench were the three on the "grease" cap.
Originally, the rear axles were plain from the factory, and they had just a tad of overspray of gree at the housing end, and maybe some yellow near the wheel if they did any touch up.
I did as many do, and painted them a flat black. Actually, I blended some flat and some gloss until I got the sheen I wanted. I painted the axle, then slid the wheels to where I wanted them, then re-sanded and repainted the portion that sticks out past the wheel.
You'll like the electrolysis process. About once a year we get a fresh crop of readers and many of them have not heard of it, so we'll go through a session or two geting everyone up to speed. It is the slickest thing I have ever used. since firing up my first tank, I no longer use my 100# pressure pot Tip sandblaster, and seldom use my blast cabinet. It's just easier to use the tank and know it will be done when I get there.
Frank
