70-730
bigblock
05-24-2007 19:19:27
FIT,where did you mount your step?It's just too much trouble to squeeze between the fender and the headlight.If you mount it on the rear you'll have implements to go around,over or between.Maybe I just have the wrong fenders on it.
F-I-T
05-25-2007 07:12:29
 Re: 70-730 in reply to bigblock, 05-24-2007 19:19:27
I don't use a step. You step on the left corner of the drawbar frame, then onto the left axle gousing, climbing on from the back.
Mike M
05-25-2007 04:52:59
You mentioned 2 different tractors and they are set up differently. If you put clamshell fenders on any of them it is very tight to squeeze between the headlight and fender. If you mount flat top fenders and have the lights in them it then opens up more room to get on from the front. Getting on from the back with any fenders and a 3 pt. is very tough indeed.
That's why I have left the flat tops on my 720D
,but I sure wish I'd of replace the brake pedals with the 730 style that lay flatter.
